okay...60 willy's cj5..original tranny and engine...I know they have alot of different tranny's buy I'm not sure which one I have...it is the
original 3-speed. I had a shop change the clutch and bearings in the tranny...they said nothing else was wrong with it...the input
shaft
measured out okay, they did not change the oil sling, but the did change the baffle...
Problem is it still leaks...out a hole on the bottom of the bell housing...it is a manufactured hole so i assume it's for overflow...the
transmission shop has no clue as to what's wrong and wants to drill extra holes in the baffle under the oil sling to aid the return feed
of oil. Does anyone know what the problem may be and if fixing it by drilling the holes can screw anything else up? It did not leak before I gave
it to them.
get a refund, and goto a better shop...
the fact that it DIDNT leak before tells me they dropped the ball somewhere
unless of course they are overfilling it?
check around and find out for SURE what the capacity is..
T90, T14 maybe?
I cant keep up with the stuff thats older than me!
OzarkJeep
NW Arkansas
