Im swapping in a D44 and D60 from an 84? J20 into my YJ.... I plan
on using the steering from a full sized Wago or J truck and adapting it
into my YJ. The brakes I plan on swapping (buying new but using) 3/4
ton J20 brakes... What all would i need for this? Should i trust my old brake
line or replace it too? Also Im not sure but im thinking I might have a
problem with the pumpkin being where a spring pad needs to be. I plan on
runnning these SUA for the time being. Thanks for all your help.
Dustin
JeepChild
If its not too far off...often you need to grind down part of the pumpkin for a foot holding for the spring pad...I ground a flat surface into about 3 inches of my chevy front end on my jeep.
~~TIM~~
CJ-7 10"lift
are you narrowing the axles Dustin?
you need
a welder, some grinders, lots of fabricating skills
if you shorten the front axle you can get the spring pad off of the front diff
if the brake lines will fit ( they probably will) then reuse them if they are long enough
the steering should be pretty easy to make work
I still think you woul dbe ok with Dana 44s since you have an Automatic though!.
how did it go this weekend?
OzarkJeep
NW Arkansas, need a CJ rear seat
