hey i was driving my truck today and i went to push the clutch in , the pedel went right to the floor and its a hyrualic clutch and i noticed under the truck there is a puddle of fluid , i was searcing the web to see what i could come up with and im guessing its a (SLAVE CYLINDER)? well ill leave u with that i hope some one can direct me in the right direction thanks alot Greg Van........
There is only three places it could be leaking from, the master cylinder (located at the firewall), the line itself which runs from the master cylinder to the slave cylinder, and the slave cylinder which should be mounted right below the starter with two bolts through the bellhousing. On my truck the line was a dealer only item, but I managed to get the right adapters for it and used regular brake line.
