I bought the Crane Adjustable vac advance kit from
Summit, and had that on for a while, then I took it
off and went back to the stock unit - there were so
many adjustments I was overwhelmed. The only mod I
have on the HEI at this time is one of the heavy
springs from the Crane kit, and one of the light
springs, for the mechanical advance. I think this flattens
out the mechanical advance curve some, bringing some
of it in at a lower rpm (the light spring), and
reserving some for the higher rpms (the heavy spring).
The stock GM springs are very stiff (heavy). I have
an automatic tranny, and use a lot of the rpm band,
and with the stock springs, I found that if I set it for no
ping on the highway at higher RPMs, it was really
doggish around town (no advance in the lower rpm range).
This setup seems to work best for
me. If you have a standard tranny and don't ever see
2500+ rpm, you may be ok wiht the stock springs, or may
want a different combination. Other than the correct
gear, I have made no other changes. I also run it off
of manifold vacuum, not the port on my weber carburetor, and
the regular chevy vac can seems to work ok for me.
Good luck
Pete
