I have looked around and searched. They both seem like viable upgrades, but the HEI seems simpler,,,, Which do you guys recomend for a 79 cj5 6 cyl??
In reply to:
For the HEI, you will need the distributor, a new drive gear, and to replace at a minimum the cap and rotor.
[/ QUOTE ]
Actually, there is another write up on just using the HEI module with the duraspark distributor. That would be my choice to do. Then use the ford coil.
In reply to:
Already done - Go to:
[/ QUOTE ]
Not unexpected.
As for the rest I will have to read it a couple more times and that link too.
The back burner is over heated..... there's a friggin short curcuit... sptss pop ssss [smoke escaping]![]()
In reply to:
My questions are:
1. Duraspark I or II?
2. Were you running the resistor wire at the time of your current test? I have to take issue with your statement of longevity, otherwise.
[/ QUOTE ]
1. duraspark 1. ( I did the TR updrgade, execpt for the spring kit)
2. yes, running the resistor wire. 1.35 ohms of it. just like the FSM says too.
take issue with my concerns with longevity? I'm a electrical engineer and deal with statistical predictions of longevity of parts like this all the time, all day long. and although I didn't set up a bank of these coils and run them to termination, the first things I would do to accelerate the testing would be to double the current, and increase the number of ignitions. all I said was that it would not last as long as the stock coil. That is a really weak statement. and given the amount of current going through these parts, it is a safe bet that they will fail to TE.
