Disc brakes are self cleaning and bring a weight savings of 50+ lbs making this is a great upgrade for your rock crawler, mud bogger or pulling truck. These brackets are made to fit the mighty Chevy/GMC14 bolt FF rear axle 1973-1988 like a glove. Backed by a lifetime warranty against breakage and made in the USA with pride, this 14 bolt disc conversion is absolutely the best you can buy… period.
The brackets are machined from 3/8″ steel plate. Sharp edges are deburred before sand blasting and powdercoat. The kit includes a set of brackets with TIG welded steel spacers, Grade 8 mounting hardware and safety rings to keep your bolts from backing out. ONLY 129.99
What else will you need? • (2) Rotors (1975 -1988 GM 3/4 ton 4×4 truck front) • (2) Calipers (1975 -1988 GM 3/4 ton 4×4 truck front) • (1) Set of brake pads (1975 -1988 GM 3/4 ton 4×4 truck front) • (2) Soft brake lines (braided stainless steel lines available) • (2) Banjo bolts • Brake fluid • Common Tools
If you want to keep your cable e-brake simply substitute ’78 El Dorado rear calipers instead of the GM front calipers. Our brackets will work with both calipers.
