Guest
·I think my Jeep is P.O.'d at me. Just brought it home from the paint shop Thursday afternoon and when I was gassing up, noticed coolant dripping from under the jeep. The heater hose from the water pump to the back of the manifold had a pin hole in it right by the clamp; no prob, cut to fit and re-clamp. Well went to parts store to buy coolant to replace what leaked but before I re-filled, checked hoses, and sure enought the other side of the hose had a pin hole as well. The hose was a bit bigger than the connection and the clamps really had to be tight to keep it in place. It looks like the hose was a 3/4 put over 5/8 connection, anyway, went back to parts store to get hose, looked it up and it called for 7feet of 5/8 hose, bought 4feet and went home. The hose connection at the back of the manifold went in snug and tightend just fine, but the connection at the water pump was a different story. I could only get the hose about half way over the pipe from the water pump. I could see why someone would want to put 3/4 and just tighten really hard. Anyway I got it just enough over the pipe for the clamp to fit; Is this enough? or should I remove it, heat it up and try again (not much room to work with), or do what the last person did and buy a larger diameter hose and good clamps?
