a friend of mine has a YTM 200 that seems to blow the headlight(hi or lo beam)
whenever he revs it a bit. is there anything other than some insulation missing from the wires that we should be looking for, the wires actually look pretty good. thanks for any feedback. alex
has your buddy changed the voltage regulator??? maybe try a bigger sized bulb if that goes out then i would look in to a new regulator
between my family and i we have 3 polaris atvs and they all do the same thing the only thing i see in common with them is they all have the battery dead. have you found the problem if so could you let me know. i just started diagnosing the problem and would like any info you can give
he tried a different size bulb last weekend and it seemed to work ok,hopefully that's all it was. we're both real new to this world and don't even know where to begin to look for the voltage regulator. thanks for the input,Alex
