BETWEEN MY FAMILY AND I WE HAVE AQUIRED 3 POLARIS ATV'S ALL 3 WILL BURN OUT THE HEADLIGHT AS SOON AS YOU GET MID THROTTLE. EVERYTHING ELSE SEEMS TO WORK MOTOR WISE JUST THE LIGHTS BURN. ALL 3 HAVE BAD BATTERIES COULD THIS BE THE CAUSE OR NOT I JUST GOT INTO ATVS THIS MONTH AND AM JUST STARING TO DIAGNOSE THE PROBLEM. ANY HELP IS APPRECIATED.
check the wiring for bare wires this could be the culprit and it is grounding to the frame .... i'd try a bigger bulb before i'd pay for andother battery
i have used up to a 65 watt halogen bulb and that lasted about 10 sec. then
went poof. the ground is working to the frame ive checked that using ohm meter
and resistance checks, does anyone know how to check the regulator and verify
its working properly?
