Guest
·Here are the facts: Went Fourwheeling last weekend everything is fine. Tuesday Night Start the Jeep, It runs for about 30 seconds and then cuts out. Unable to restart it. Symptoms: Engine cranks and cranks. Jeep has gas 100% sure, looked in Carb. I figured it was the ignition coil, cap or, rotor. I decided to upgrade plugs, wires, coil, and get new cap and rotor anyway. It now has Jacobs coil and Wires, Bosch Platnium plugs and new rotor and cap. I still have the same problem. Here is what I know: I have a stock distributor. I have 12 volts at the positive side of the coil. I have spark coming form the the coil to the cap, but it is weak. I have spark at the plug wires that is also weak. What I think is the culprit is the stock Electronic Control box mounted on the right fender. The distributor's one wire leads to a wire harness that dumps into this box. Please help. I don't know anything about this box or if it can be bypassed or what. I know someone will suggest I go with a HEI ignition, but I don't have the money, plus I just bought the new Jaccobs Coil. Any insight would be great, I hope to fix this by tomorrow so I can take the Jeep Wheeling on Sunday.
