GWag D44 / YJ Swap
I picked up the future front axle for my YJ this afternoon. Its a D44 out of an 87 Grand Wagoneer. It looks like a pretty straight forward swap, and has some nice features.
*The width from hub to hub is 60 1/2".
*The springs are mounted very close to the same width as the YJ at 32" center to center(GWag) and about 31" on the wrangler.
*Shock mount location is almost identical to the YJ and are already up out of the way of rocks,in the middle of the axle tube(spaced about 38" CL to CL). But they are angled not sure, but I'll probably reposition them a bit.
*The steering linkage is already mounted, knuckle over, and looks considerably stronger stronger.
*The Trac bar mount is beefier and taller.
*Brake rotors are 12"
I cant wait to start tearing into it, and it should make for a strong, reliable combo with the Ford 8.8 already bringing up the rear. Now I just need to borrow a garage, my girlfreind says I cant use the dining room table. I told her if she cant handle the heat stay out of the garage/kitchen. If she keeps up this attitude I might just have to take my NP435/ottoman back down to the construction trailer, that'll teach her. This is the worst part about moving so much and renting.
Jeff
89 Wrangler
Jeff
89 Wrangler
