I noticed the other day that there is an auxilliary wire coming off the negative battery cable that connects to the firewall right behind the battery. My wire was pretty well thrashed and crimped and corroded, so last night I spliced in some new wire to replace it. The only wire I had at the house was 14GA, which is slightly smaller than the original that it replaced (maybe 10 or 12GA??)
Anyway, I'd just like to know what the purpose of that ground wire is (since the negative cable in itself is a grounding cable) and if using the 14GA will cause any long term problems.
Thanks!
Thanks!
