I have U joints that have a small threaded plug in the center of one cap,smaller than a standard zerk,anyone know of a zerk to fit
this hole? or some adapter for a grease gun? Have tried auto parts stores here and found nothing
Buy a pointed needle shaped fitting for the hose on your grease gun. This has worked successfully for me for 15 years. Use a plumbing fitting and attach two hoses together for better reach and articulation if you so choose.
the zerks you are looking for are called "cup" zerks. they requir a needle fitting to use them.
dan
Lone Eagle -
Jeep Joe and Blackjack are dead on in their posts. I can add this for what it is worth: My Tom Woods CV rear driveshaft has three of those suckers on the CV end. I have to remove the whole thing from my vehicle each time I lube it. However, I don't mind. (Iwuvmyjeep)
sln
Well i pulled the plugs,got a needle,it leaked a bit but did force it enough to come out of the other caps,these were located in outer
front axle joints (ford truck,not mine but my brother again) :-/ thanks all
