Guest
·yeah i had to go to store for right size hose clamps- you know the routine!
i hope i didn't alter your design much if at all..
i drilled a hole in the clamp and bolted the rubber gizmo to the clamp with a small fine thread bolt, flat washer, lock washer and nut. then i rotated the whole assembly around on the shock till the brakeline found a comfortable position out of harms way. i like it and thanks again for the design!
grasshopper do good grandfather?
you can't see the rubber gizmo that the brakeline rides in but it be there!
here this one maybe-
i don't know, after looking back at your post, grasshopper may have failed. i might need to bring the clamp down further on the shock to get that play out of the top end and get it further from tire.
