Paint??? Find out if the heat build up has any effect on which if any paint you should use. I don' t know, but the thought crossed my mind that 1) the heat might burn the paint off and 2) the paint might cause the unit to run hotter. May be off base here, but doesn't hurt to ask around.
Tank?? You can buy or build. I have a shop built tank made from heavy wall 6" round tube. The ends are welded with 1/4" plate. The pressure switch cuts off at about 115 psi. This tank also has several outlets, some of which have been plugged because I no longer need them. It's ugly, its been modified more than once - even had a big chunk of the side cut out and rewelded so that it fits around the new transfer case. It still works.
QuickAirII makes a small tank - a couple of gallons, I think - for about $80, but I would not feel good about modifying it because of the thin walls. My choice is shop made. Hope this helps.
Doug '97 TJ
CBrack.com
Doug '97 TJ
CBrack.com
