Guest
·I am currenlty modifying the front and rear end of a 1/2 ton suburban to put under my jeep. I have the original steering box from the chevy alone with the steering linkages. I have moved the rear perches to the stock jeep dimensions, and I plan on doing a spring over convesion during this swap. The rear end is simple.....but....inthe next few days, I am tackling the front end. I have moved the drivers spring perch in two inches and cut a small piece of the pinion housing to accommadate the move of the passengers side perch. Everything looks good so far, but I am wondering about the steering mechanism that I want to encorporate. Should I fabricate the linkages (steering arm..etc) to fit the application, or should I move the steering gear box and try to keep everything else "stock" from the chevy? If I move the steering gear box, I will have to lengthen the steering shaft...no big deal. What do you think? Thanks, ~TIM~
83 Cj-7
85 Cj-7
85 Suburban
83 Cj-7
85 Cj-7
85 Suburban
