If someone was rebuilding an engine , say a 360 AMC . You want to do as much as possible yourself , so you send out the block and crank for boring/turning etc... Have the shop install the cam bearings and stuff . Now when you install the crank and rods and check for crank end play and rod clearances , what if the end play and or rod clearances arent to spec ? How would you rectify that situation ? Or would that mean that the machining that was done was of poor quality ?
Jeff /wwwthreads_images/icons/cool.gif
