Either will probably work just fine. I run an 86CJ7, 258 I6, NV4500, 4.88:1, and 32's. The NV4500 is 27% overdrive. This is effectivily
a 3.56:1 final drive ratio. I tach appx. 2650rpm at 70mph. I only have to down shift on the worst hills. The T5 is 17% overdrive. This is
a final drive ratio of 3.41:1 with 4.11:1 gears and 3.78:1 with 4.45:1 gears. Your 33's will drop the rpm's a little. Hope this helps.
Gary
Gary
