If there is any chance you want to add a locker, now is the time. Otherwise, you will have to get the old ring gear of the carier which may require a press. Plus, putting in the locker the same time you do gears is only one setup. If you add a locker later, you have to do it all over. As we speak I am adding an ARB and 4.10 gears. So far the hardest part was getting the old pinion out of the diff. My diff wouldn't fit in the press so I had to rig up somthing using a steel table and a hand hydraulic jack. The other hard part is getting my old spring perches off. I figure I can get about 1/2" of lift by doing away with the wedge shims....and get my driveline angle closer to what I want.
One last thing. If you have the AMC 20, replace the old flanged axles. I am also installing the Superior one piece solid axles. One of my old axles was on verge of spinning. The spline on the hub was already striped. The key was the only thing holding it. The Superior kit has everything you need and there is no shimming required. Nice setup.
John......southern CA
