Guest
·1986 Honda TRX 125 Two wheel drive, auto clutch (shift gears w/o any clutch; it has not clutch.
Last week the chain came off the rear drive due to two of the axle adjusting/retaining bolts falling out. This allowed the axle to shift forward and let some slack get into the chain and the chain finally walked off. The chain did not "ball-up" behind the drive gear; it just stayed flat on on rear axle.
We got the ATV back to my shop and started looking at a few things.
The problem I am having is that the ATV seems to be stuck in gear and will not go into neutral. I have the green neutral light on the instrument panel and it works, so I know that it is not shifting into neutral. In fact, when you try to depress the foot shifter, its just stays in the same location as if it is stuck.
I need the tranny to go into neutral so I can pull the chain around the engine drive chain freely and rehook the chain master link.
I have the Honda factory shop manual, which says such as shifting problem may be a bent shift rod.
What do you think I should do next to try to fix? My boys' are after me to fix their toy.
Thanks for any help.
Replies
Replies
