Absolutely not! You will eventually break something if you are not running the same gears. In mud it will be ok because there will be some give as the tires move at different speeds, but when the ground does not give (i.e. dirt, rocks) as the tires move at different speeds you will break something.
Metal Thrashing Mad
I'm a madman at the wheel
NFT
"Your decisions must be honest & true"
