Gear oil coming from passenger side front wheel bearing?
420 Views 1 Reply 0 Participants Last post by  utahjeepr
I have an 88 Wrangler and I noticed gear oil coming from the front passenger side of the axle. Is this just a seal behind the bearings or is the seal closer to the diff? What tools and parts will I need to fix this? I'm no master mechanic but I try to do everything myself just so I can learn. Thanks for any help you can provide.
The seals are inside the diff. behind the carrier bearings. You have to pull the carrier to replace them. Don't worry though, you don't have to set up the R&P again. Just pop the carrier out (you have to carefully pry on the carrier to get it out), change the seals, and pop the carrier back in. There is also a grease seal for the wheel bearings on the back of the rotor, but since you said gear oil I assume you are talking about 90 wt coming out of the axle tube.
"My other car is a BULLDOZER"
