Okay, I'm going to do a 1" body lift. I plan on getting the Currie 1" motor mount lift to go along with it.
My question is, how hard would it be to lift the gas tank 1" also? That would keep it from getting hit as often, so why not?
_____________________
John
95.5 YJ with "stuff"
http://SonsofThunder4x4.com
interesting idea, if the body is the only thing above the tank you will just have to move the tank mounting points up 1 inch, if the framerails are over the tank then you are gonna be out of luck or into serious mods, remember that the fuel lines are probably attached to the frame so you will have to modify them a bit in order to mount the tank higher.
