Guest
·I have added the cap,rotor and wires to my 87 yjw/258-6.The difference was hard to believe.Acceleration is smooth to past 3500 rpm and it starts much easier. In an earlier post I had said I would report back on the change in mileage after a tank or so.The mileage has improved to 14.1 mpg vs 13 before the change.My question to TeamRush is,will the tfi coil make as much improvement as the cap,rotor and wires?I had been using a jacobs omni pak before,but with the new cap it actually runs better with the stock coil.If the tfi works as well as the cap it will be more than worth te 40$ it cost at the parts store thanks for the help TR rh
