Guest
·I just installed the painless wiring harness, new autometer gauges, and a 20 gal poly tank. My fuel gauge is the only thing that doesn't work. I ordered the gauge to that went with the fuel sending unit so unless they sent the wrong one... The only thing I didn't do was ground the gauge itself to the tank as per the autometer directions. I just grounded it the tub. Is this where I screwed up? If so do I ground to one of the screws that holds down the sending unit? How else would you ground to a poly tank?
Can you fix it?
I got a welder and a grinder. Heck yeah I can fix it./wwwthreads_images/icons/cool.gif
Can you fix it?
