I am putting FSJ axles under my Jeepster, and of course no one makes lift springs for it. I am moving the front springs outboard of the frame for the Dana 44. But my real question is what are the spring dimensions for the FSJ's. My front axle came out of a 78 Wagoneer and the rear springs on that truck measured 56" long and 2-1/2" wide but I could not tell if these have a centered or offset tie bolt. I also measureed an early J-10 rear springs that were 55" long with an offset (33/22?) tie bolt that I might can make work on the front. The Jeepster rear springs are also 56" long x 2-1/2 wide, centered tie bolt, but are flat. I am also interested in the dimensions on the front springs. Do they vary from year to year, or application to application? Could someone clear up the muddy water for me.
Carey Smith
71 C101
95 Ford Bronco/wwwthreads_images/icons/crazy.gifYes, I traded the YJ for it
Carey Smith
71 C101
