1 - 13 of 13 Posts
FS - \'85 CJ-7 whole or parts
This is all from a 1985 CJ-7, which shows 89k miles. Not sure if actual mileage or not. Runs & drives now but is likely worth more in parts than whole... I will sell it either way.
If you think the prices I've listed are out of line, make offers. Make offer for the whole Jeep, make offer for lots-o-parts, make offers for one part, make offers for anything... I am flexible.
All parts are located about 5 miles North of Grand Rapids, MI. I will ship anything. We can negotiate who pays what. We can also negotiate possible meeting halfway for exchange, as larger items are not cheap to ship. US Postal is usually cheapest. My zip is 49341 if you'd like to estimate some rates. US Postal, FedEx, UPS all have online rate calculators.
The body tub is rusty, has some cheezy repairs and pop-riveted floor panels. Frame is little rusty too, has good rust repair at rear spring shackle hangers and could use some rust repair at the rear spring main eye hangers. Ask questions or make offers if interested in either.
$200 - title & VIN tags
$60 - wide track AMC20 rear axle, straight, GC, 3.31 gears(not sloppy) complete drum to drum
??? - wide track D30, housing is slightly bent and 5 bolt locking hubs have missing parts so will not unlock, 3.31 gears(not sloppy), carrier, all axle shafts, knuckles, spindles, wheel hubs, calipers, tie rod, drag link, etc - GC ...parts or whole, make offers
$50 - front & rear (all four) OEM springs, GC not sagging
$25 - front & rear ( all four) HD shackles 2" or 1" over stock length
$50 - 5 OEM chrome 15x8 CJ steel wheels, 4 have center caps, straight, not rusty, GC
$20 - OEM front drive shaft 29.5" collapsed length, no u-joints, tight slip joint
$20 - OEM rear drive shaft xx.x collapsed length, no u-joints, tight slip joint
??? - OEM front drive shaft 31.5" collapsed length, no u-joints, loose slip joint
$125 - D300 transfer case, GC, shifts fine, does not slip out of gear, includes shifter or will separate
$225 - T5 transmission, GC, shifts fine, does not slip out of gear, includes BH and t/c adapter and shifter or will separate
$50 - 258 engine, always starts & runs but has low oil pressure and other signs of wear, complete carb to oil pan - will separate
$20 - radiator for 258, no leaks, GC
$20 - 258 flywheel & clutch
$10 - mechanical clutch linkage
$25 - OEM air cleaner hsg for 258, includes vac motors and thermal switches (have two - one complete one has no cover; make offers)
$15 - manual disc brake master cyl, GC, no leaks good pressure
$40 - power steering box & pump, incl hoses & brackets, OEM pitman arm, box could use an input seal otherwise no leaks and GC
??? - OEM steering shaft
$50 - tilt steering column, incl steering wheel or will separate
$25 - complete set of pedals; clutch, brake, throttle
$50 - CJ grille, GC, small surface rust at bottom, straight, incl all lights or will separate
??? - grille support rods
$50 - CJ hood, GC, small surface rust at hinges, incl hinges, latch and support or will separate
$10 - both fenders, small amount of typical rust, small to med dents in front of each
??? - tailgate, rusty around one hinge, otherwise GC
$30 - dash, incl glove box & door, grab bar, all guages & switches or sell separate
$30 - windshield frame, small amount of surface rust, no glass
$15 - windshield frame, rusty rusty, good glass
$25 - wiper motor, linkage and wiper arms, GC
$30 - left and right flip forward seat frames - front seats are blk cloth from a Chevy Cavalier or something, useable condition, make offer if interested
$30 - non folding rear seat, Levi's edition blue denim vinyl, GC, dirty but no tears
$75 - black hard top, GC, good tinted side glass, cheezy homemade wood liftgate but the OEM tinted liftgate glass is good
$300 - hard doors, dark red interior and exterior, VGC, no tears, windows roll up/down
$50 - Bestop SuperDoor 2pc doors for YJ or CJ, black, no tears, GC
$20 - OEM roll bar
$20 - complete front seatbelt assys, left & right
$15 - newer steel gas tank, clean no rust
$40 - OEM heater assy, GC, incl ducts, heater core and blower motor or sell separate
$15 - OEM sun visors, one set red VGC no tears; one set black small tear on one useable cond
$10 - windshield washer bottle with newer pump
$10 - battery tray
??? - charcoal canister, vac res
??? - OEM dashpad, red, vinyl cover is GC but needs the mounting tabs repaired
???? - computer, wire harness(es), solenoids, switches
??? - fuel filler, license plate holder
Anything I missed????
Other Jeep parts ---
$40 - aftermarket replacement CJ spedo cluster, 6500 miles on odo, incl required sending unit
$30 - D30 front wheel hubs & locking (6 bolt) hubs for disc brake (fit any CJ D30)
$60 - narrow track AMC20, GC, 3.54 gears(not sloppy) complete drum to drum, needs small brake parts replaced, bearings tight
$60 - narrow track D30, GC, 3.54 gears(not sloppy) complete drum to drum, needs small brake parts replaced, ball joints tight, bearings tight, locking hubs good, axle shaft u-joints little loose, incl tie rod and drag link
$100 - narrow track D44 rear axle, 3.73 gears, OEM trac-loc, flanged axles, complete drum to drum, will need some small brake parts, from postal Jeep
$225 - custom built rear bumper/receiver/spare tire carrier combo. Bolts to TJ, will fit YJ or CJ with modification of mounts. Swing out pivots on replaceable, greaseable bushings and locks tight (no rattles) and will safely hold up to 35" tire. Tire mount has 5 on 4.5 (TJ/YJ) bolt pattern, will need modification to carry 5 on 5.5 pattern CJ wheel (have wheel hub to make this change). Retains TJ OEM 3 rd brake light. High quality construction. Have pictures.
thanks
andy
Re: FS - \'85 CJ-7 whole or parts
I will take these parts!
Rodney C
1985 CJ7,302 V8,T18,D20,SOA,Shackles Reversed, 35" BFG AT's, Fiberglass Tub & Front End...
1990 Samurai,87 drive line,SOA+2.5" Add-A-Leaf,4.16's,5.12's,33" BFG's Mud's,Pony Carb...
I will also take this off your hands
Rodney C
If you Part out I would like the following things//
$10 - battery tray
Contact me at [email protected]
John
Damn the Mud!! Full speed ahead!!!
http://www.Marylandmudbugs.com
e-mail address in your profile is broke...
I'd be interested in the steering column, steering shaft, pedals with mount, if possible, windshield frame without glass (least rusty), and something not listed- the plate on the firewall, driver's side, in the engine compartment. Don't know if that's bolted or spot welded. Might be interested in VIN tags and title, as well.
Let me know what you need for the bracket and that plate.
Thanks.
woha, sorry.
didn't expect this much respose so soon. perhaps a bit foolish to think that, huh.
I'll track all responses and requests, then reply soon as I can get to it all (there is a ton)
many are going to my e-mail, not sure why some are having problems. the address is [email protected]
thanks all
Hey!
Let me know about the Dana 300. I'll be out of town util thursday, But if you save it for me, I'll buy it. You can also e-mail me at: [email protected]
Paulee
'94 YJ Pro-Comp Coil-over kit. 33's
....and a cranky T-case.
Andy,
Sent you an email-----
I am interested in the narrow track dana 30 that you
have for sale. I would like the whole thing, but I
think shipping would probably be quite high from MI to
TN. Would you be interested in selling just the axle
shafts (inner and outer)? I would pay for shipping.
Tom
Trailsman, I am interested in your custom rear bumper.
Can you send me some pictures. I need one for my CJ-7.
Thanks RCJ7
1 - 13 of 13 Posts
