1 - 13 of 13 Posts
I have a 1980 T-176 and D-300 out of a CJ-5.This includes tranny,adapter,t-case and front and rear drive shafts.This is the short 300.The bell housing is not included,I need it for another project.I'm asking $350 for it all.I'll be using this money for a T-18,Dana 20 setup I've found.
F.T.D
77 CJ7,79 CJ5 Plow Jeep.
I don't want to seperate the setup because I don't want to get stuck with a tranny I can't use.I can always put the set up in my 79 CJ-5 for an upgrade.I'm located in Colebrook CT.
F.T.D
Re: FS 1980 T-176 and DANA 300
How much you wanna spend for it? I have one as well, it's mated to an SR-4, so I don't mind separating it.
JEEPN
Winter Harbor, Maine
I was cleaning up the T-176 tonight and the output shaft looks like it has a bit of wear on it,the splines are about half worn.The shifter on it needs the boot that holds the pins in,its torn and it also needs the cap that rides on the pins that holds the shifter in.I think those parts are about $15.00 from 4wd Hardware.The 300 has the strap type u-bolt hold downs and a couple of the bolts need to be drilled out but otherwise its ok.
On a differnt note how do you like your ZJ?I'm looking at a 94 myself and was wondering what kind of problems to look for.
F.T.D
The ZJ is a good car. I have owned about 9 months and it has 136,000 miles on it. The weak parts on a 94 is thr viscus coupling in the 249 t-case used with the V-8 that is very sensitive to improper tire size. This is a full time case and the coupler allows slipage when you turn. If you have one tire that is not the same circumference as the others, the coupling will overheat and fail in the locked mode which is not good. A lot of people replace the t-case with a hybridized 242 case that is a bolt in swap that gives you part time 4x4 and 2x4 modes. I swapped in a '96 249 which has a low lock feature the earlier ones didn't have because this Jeep is mainly a grocery getter and is used by my daughter as a first car (i.e. good crash protection). Transfer Cases Unlimited in New York sells both t-cases for about $900.
The other problems are that it's a real pain to get to the distributer cap on the V-8s and the air conditioner condensate drain clogs up wich spills water into the right rear passenger foot well.
I enjoy the ZJ and it make a much better tow vehical than my 83 Dodge Long Range Ram Van which also has a 318 (carbed, not FI), 4-sp manual trans and a 35 gal gas tank. I wish the ZJ or the CJ could get 550 miles to a tank of gas like that van can.
Karl
80 CJ/YJ-7 FrankenJeep
94 Grand Cherokee
The ZJ is a good car. I have owned it about 9 months and it has 136,000 miles on it. The weak parts on a 94 is the viscus coupling in the 249 t-case used with the V-8 that is very sensitive to improper tire size/preasure. This is a full time case and the coupler allows slipage when you turn. If you have one tire that is not the same circumference as the others, the coupling will overheat and fail in the locked mode which is not good. You can test this by driving it for a while and then make a very tight turn in a parking lot. If you hear a groaning noise or the front end starts to buck, the VC is going bad.
A lot of people replace the t-case with a hybridized 242 case that is a bolt in swap that gives you part time 4x4 and 2x4 modes. I swapped in a '96 249 which has a low lock feature the earlier ones didn't have because this Jeep is mainly a grocery getter and is used by my daughter as a first car (i.e. I wanted good crash protection). Transfer Cases Unlimited in New York sells both t-cases for about $900.
The other problems are that it's a real pain to get to the distributer cap on the V-8s and the air conditioner condensate drain clogs up which spills water into the right rear passenger foot well.
I enjoy the ZJ and it does make a much better tow vehical than my 83 Dodge Long Range Ram Van which also has a 318 (carbed, not FI), 4-sp manual trans and a 35 gal gas tank. I wish the ZJ or the CJ could get 550 miles to a tank of gas like that van can.
Karl
94 Grand Cherokee
Discussion Starter · #12 ·
Neal,I need to have a shipping address,preferably a business address so I can find out how much the shipping will be for you.
F.T.D
1 - 13 of 13 Posts
