front poping, please help with any input?
590 views 7 replies 4 participants last post by  **DONOTDELETE**
Hi all you samurai owners,
have you had your locking hub, unlock and pop while 4wd?
I was out 4 wheeling saturday and the front drivers side started doing a real loud poping sound....
at first I thought it was the birfeld, but when I took it out of 4wd and drove home, nothing seemed
broken, no grinding or steering dificulties.....
or could it have broken and I not notice it when not in 4wd.....
I do not have a front locker and am running 31's......I have been told that with that setup, I should not have any problems with the birfeilds? I am running 4.16 t-case and a 1.6 16valve sidekick engine...
any thoughts or tests I can do to determine if it is something wrong with the locking hub or the birfeild?
thanks for any help...
Rich_D
If you do not expect the unexpected, you will not find it.
When I was wheeling a good while back, I tried to tackle a good sized hill and had a no go. A month or so went by and I tried it again, walked right up. Turns out I had one hub disengaged! I do not know if it was from me forgetting or if a hub magicaly unlocked byitself. I heard no grind or bumps, anything, she was working just fine.
I'm LOCKED!
Got zook?I do,88.5 spoa'd on 29'shttp://www.geocities.com/bik3r
#4 ·
It could just be the hub. I had mine grind real bad and had to remove it and take it apart and re-grease everything, and put it back together. I think a spring/clip was mis-aligned, but not sure. It was my first hub rebuild and everything worked fine after that. Hope yours is as simple.
Scott Trester - '88.5 Suzuki Samurai
http://RockPile4x4.tripod.com/Scott.html
#5 ·
ok, I took it into a place last Feb and had the front brakes replaced and the front bearings repacked....
this was before I tackled working on anything or realized how easy this was to work on....
I had done several other things and really did not have the time to do it myself at that time.....
anyway, it was not a grinding but a loud poping sound....both hubs were in a locked position,
but it sounded like the hub was racheting.... loosing the locking...
I have NO side play..... so I don't believe it is the bearings.....
what I would like to know is how to tell if it is the birfeild blowing out or the locking hub?
Rich_D
#6 ·
rich...i had it happen to me a few months back....it was a combo of things.....and yes, the hub either magically unlocked, or i forgot to lock it....that was one problem.....another contributor was the motor mounts are non-existant.....which means every time the wheels slip the motor jumps and slams up and down.....
ROACH Da NastyPimp/wwwthreads_images/icons/wink.gif
88.5 Zuk Calmini header/GRS1/235MT/Lock Rite/Centerforce stage1/wwwthreads_images/icons/wink.gif
#7 ·
was the poping you experienced a rapid pop. pop. pop. pop. sound? a while the wheels were spinning pop pop pop sound...?
that is what mine did...., but I need to replace the transmission mount soon, so I will see if the engine mount went bad since I put it in, maybe 1000 miles ago... but I don't think that is the issue... thanks though
I will have to see if my hubs have any magic in them..... I am hoping that this was the problem, I don't have the
money to replace the birfeild......
any more input/experience from anyone....
Rich_D
If you blew the Birfield, then you would only hear the snapping or popping of the exploded gear while the hub is locked.
I drove my Zuki 180 miles home on a blown drivers side Birfield and only twice did I feel it try to bind while turning. However, I did have all the gear oil leak out of the axle, making it pretty obvious that I had blown the Birfield.
Neal the Zukiguy
