Although I have 27 years experience in the Off-highway world (and I'm 29), I am kinda new to the jeep world but definitety hooked, BIG TIME! I have a new TJ with the 30" tire package, dana 44's, and just put in a detroit rear locker. I put in the the locker on the advice of some long time 4 wheelers. I'm not into looks too much. I want a trail worthy jeep for the best buck. So far, The rear detroit is amazing! I was told the next thing to do should be a front lockrite locker. I was thinking of an ARB so I can disengage when turning. How will a front lockrite handle. Will I break parts with a stock front axel? What are the weak parts I should Carry For spares? Is an ARB worth the extra money? If I get the lockrite will I need to get some warn locking hubs so I can unlock one if I need to?
Thanks and see you on the trails!
rickshaw with TJ, rear detroit
For best handling, given the two options you presented, the ARB would be your best choice. The down side of the ARB is its weak link--the compressor and air lines. If either fail--and the air lines sometimes do--you're stuck without a functioning locker.
The down side of the front Lock-Right (or EZ-Locker) is that you retain the stock carrier, also the weak link.
An outstanding option to consider is matching your Detroit Locker with a Detroit True-Track. I have this diasing differential in the front of my Y2K-TJ and it works great. There are no clutches to wear out, its carrier is much stronger than stock, and you save the expense of a compressor. In real-world practical use, you will not notice the difference between a front locker or the True-Track, except you don't get the bad manners in steering when in 4X4.
Spare parts might include a spare set of springs for the Lock-Right setup (the dual springs can fail, where the EZ-Locker's single spring and bearing can't), or a set of hoses for the ARB. Also, a spare compressor or carrier, sealer, and gear oil wouldn't hurt.
Hewgag
Right Wrongs Nobody
As nice a Limited Slip the Tru track is, it is by no means a true locker, and it WILL let you down as far as traction some time down the road (or trail).
I have run a front lock-right and a front ARB (most recently) in my Toyota, and I can say that front ARB's are the way to go. You will save your front axle from wear & tear until you need the locker.
David
Davids 4x4 Page
If you plan to run any tight trails you will either do a lot of backing up or install hubs or a dual shifter to eliminate stering difficulties with anything but the ARB.
80 CJ5, 52M38
