A friend and I checked out the system, and everything seems to be Ok. Just put new pads on (not the lifetime warranty ones :) but the front driver-side brake keeps freezing up on me. We're thinking that the caliper may need to be replaced, as something could be happening there.
Any suggestions? Thanks!!
Dan
"Where are we going, and what's with the handbasket?"
Get new calipers !Your new pads will thank you! :)
91 jeep cherokee 270000 kms deceased
93 jeep grand cherokee living 213000 kms
I would start with the calipers and if that don't do it, it will be the proportioner, that is what it was on my dads 82 chevy half ton, it did the same thing. Hope this helps mason
Thanks to you both. That's what I'm planning to do first thing tomorrow. Everything should be good to go then. I can't wait to get my rig going again! Been driving my wife's Honda Civic around in the meantime, and I feel like I'm driving a little toycar. ;P
D
Ahh, habe you tried greasing the mechanism?? Gunk in the joint will cause these things.
'88 MJ SporTruck
365K on 2.5L (Energizer Bunny Package)
Did you bleed the other three wheels to be sure that your left front brake isn't doing all the work? Plus you should probably replace the rubber brake hoses. They crap out from the inside out sometimes. Hows the pedal feel?
Cool note, I'll check that out with my friend before we buy the new ones. (if we do.) The pedal felt normal even when the brake froze up. No sponginess or going all the way to the floor.
Thanks!
