Guest
·I was out wheelin' one day and when I parked my '85CJ7 I noticed a small but steady stream of oil dripping from the pan. When I got under it I noticed that my front drive shaft had slammed into the oil pan. The u-joint only dented it but there is a small pin on the drive shaft that gouged the oil pan causing the leak. Before I bought the Jeep it was in a front end collision (front rt.). I imagine that the shaft hit the oil pan when I was trying to pull out a Blazer on a snowy morning, (the Jeep was bucking pretty hard) but I'm not sure. At rest, the shaft has about 1"of clearance btw itself and the pan. Does that sound about normal? Has anyone heard of this problem?
Thanks for your help.
Andy
Andy
