1 - 9 of 9 Posts
Is there a reason that the replies to a post can't be seen unless you click on each one after you login? I've noticed they are all shown if you look at them before you login. Whats the purpose of having it one way for login and the other way if logout??? Make them all visible on login, much easier to read. Steve
Mopar360yj
D60-44-4.10
Go into the Edit profile and edit your display options to show expanded threads.
Ah yes that is much better, Thanks FNG. I guess I showed my computer savy.
Mopar360yj
D60-44-4.10
Well, maybe you can help me again. I changed to expanded threads and they show up on the forum but they still don't show up when I click on the individual ques. It shows the num of responses, but I still have to click on each response to read it. That only happens after I've logged in. Is that just the way it is?
Mopar360yj
D60-44-4.10
It is in threaded mode. Next
Mopar360yj
D60-44-4.10
I believe I have my settings adjusted the way you want them... here's how it goes...
Default display mode: Flat mode
Default view: Collapsed Threads
this shouldn't matter but i also set "Total Parent Posts" at 150, just because it involves less flipping thru pages to see older posts...
hope that helps...
Tim
"The_Sandman_454"
'79 GMC Suburban 4x4 and '85 GMC S15 4x4
Yes, that seems to have done the trick. Thanks, Steve
Mopar360yj
D60-44-4.10
1 - 9 of 9 Posts
