Ford 9\" 28 to 31 spline ?s HELP
I have an opportunity to buy a 9" 3rd member with the gears I want in almost new condition for $200. The only problem is that it has a 28 spline mini spool in it. Can I put a 31 spline mini spool in the 28 spline carrier? Just swap mini spool for mini spool?? I think someone told me it could be one but I want to verify that before I buy this. I don't need to get screwed.
Aaron
Re: Ford 9\" 28 to 31 spline ?s HELP
should not be a problem. my only suggestion is that if your carrier is a two pinion (single cross shaft), try to find a four pinion, as they are a little stronger. or since you are wanting a spool, go all the way and put a full spool in. they are not that expensive, and are much stronger.
dan
Good things come to those who do research!!
This is really just a way to get the 9" going in my TJ cheap. I will swap to better stuff before long.
Aaron
