Re: Ford 8.8\" to Dana 35 install differences??
I had my drive shaft shortened by about 1 1/2" when I swapped to the 8.8 I think I would go with a 2" crop if I did it again. I didnt listen to the expert advice from my drive line expert, thought it would be to short with all of the rear travel. but anywhere between about 1 1/2 and 2" will probably be where youll settle. You will be able to drive home with the stock shaft, provided you have the bolt on yoke. Its a very tough yoke set up, i broke a main leaf spring on a steep hill last night and it caused the axle to wrap so badly that it binded the drive shaft and pinion yoke and shattered one of the bearing cases in the pinion yoke on an almost new spicer U joint, no dammage to the yoke though, I guarentee that same incident would have destroyed the D35s weak yoke,( I used to have carry at least 2 spare D35 yokes). I cant remember what post i saw it on but someone had mentioned that the 8.8 gives up 1. 75 inches of clearance to the D35, I carefully measured before the swap and immediately after, with no other mods performed but the swap and I lost only 1" of ground clearance.
Jeff
89 Wrangler
Jeff
89 Wrangler
