Explorer Upgrades
1786 Views 3 Replies 2 Participants Last post by  Drey
I own a '93 Explorer, 4dr, 4x4, manual transmission, with 6cyl. 4.0L engine with 105K on it. I have had it for about a year and a half. For my first vehicle it does everything I ask... it could just do it better always I suppose! I realize if I wanted to go fast and have a racecar the last thing I would want is a big SUV... but I'm in need of some performance upgrades to help me get a little better gas mileage. I change my oil, flush radiator, injector cleaner, and put a K&N air filter in today (we'll see how it works) on a recommended basis and I would venture to say I drive safe and don't abuse the accelerator at all. Drive on average 50/50 Hw/Cty. My problem is though that I’m getting around or less than 200 miles to a full gas tank. Which comes to somewhere around 10 mpg some weeks!! At best I get 240 on a full tank on a long trip or something! I really need some tips from real people instead of reading packaging or company ploys on what will actually get some better numbers here. And at the same time, spending $400 to save $3 dollars a week isn't what I'm looking to do either if you know what I mean! I would desperately appreciate any advice you could give!thanks!
A Tornado would probably help a lot. It goes into your stock intake. You see them used a lot on Hot Rod shows lately. I don't their website but I'm sure if you check around on the web you'll find it.
what tires, tire pressures, and gears are you running?
a lot of guys dont seem to realize that running big muds @ low pressure increases the rolling resistance ( drag) a ridiculous amount...works great for traction, but not mileage. Ditto for gearing - if you're rpms are out of the powerband a lot, and / or you're trying to make up for bigger tires with brute force, mileage will be terrible.
other common 'mileage boo'boos', including high speed driving with safari racks on top ( or a pod carrier), and weight gain from off-road bumpers, nerfs, winches, etc. ( add enough toys, and you might as well be towing all the time...but its easy to forget that the extra weight adds up to $$$ at the gas pump) On the repair sdie - what shape are your O2 sensors in? if they're not working right, your mixture can be off, and both power, and mileage will suffer.
chris
2
yes o2 sensors can kill your performance big time. My 91 with a 4.0 one went out and it ran horrible i got like 8-12 MPG had didly power. Although it was a 91 with 218,000 miles. 2nd motor, 2nd tranny, 2nd set of 4x4 hubs But my dad got rid of it...i miss it actaully.
See less See more
