Ok, i have a 88 2 door Xj, with the 4.0 and 5 speed. A month ago the clutch slave cylinder went out. I replaced it, and when I was dont the engine will not run right. At first, it would barely start, and die immediately. After I replaced the fuel filter, removed fuel tank and emptied, put new gas in with injector cleaner, new plugs, cleaned injectors one by one, and fuel rail and checked firing order, it will start, will like [censored], and die if floored. It will keep running on it's own for about 10 seconds at idel after start, then just die. If you play with the gas, up down up down quickly, you can keep it running for about 30 seconds before it dies. it sputters and back fires while running, and sounds like a tractor. The pedal seems to have no effect on how it runs. What could be wrong? What am i missing? I've been trying for a month to get it running, and nothing works. Adam
