Guest
·I'm building a 1984 Jeep CJ7 from the ground up to serve as a everyday driver(No rock climbing for me, but maybe the occasional mudding and beach use). This CJ7 had the following from the factory: Iron Duke 4 cyl, 4-speed, dana 300 transfer case, PS and DB's. At the moment, the engine is gone, the trans and xfer case is still there, a dana 44 is in the rear(30 in front) with 3;73's in each one. Also a 4 inch suspension lift has been added. Future plans include a glass tub and tilt front end, new pre assembled wiring harness, 35' tires, shackle reverse and a engine/trans swap. I want to switch over to a V6/V8 with a 5-speed manual. I was wondering if anyone knew of anything that I could take straight out of another vechile, rebuilt, and it will bolt into the Jeep with as little or no problems at all. What about the 4.0/4.2 5-speed Jeeps and Cherekee's? Would everything just bolt right up if I could fnd one? If so what years/specific vechile should I look for? I prefer a engine with fuel injection if possible, but I'm not really sure how to wire up the computer to the new wiring harness. Any help/pointers would be greatly appreciated. Please Email me comments/suggestions as I don't check these pages everyday. Thanks
Chad
[email protected]
Chad
[email protected]
