Ok...I've been playing with the idle on my 258 cid and noticed a tapping sound coming from the valve train. From what I have read it seems that 258's are notorious for valve train noise but this is a fairly loud tapping sound. I took the valve cover off and grabbed all the push rods and found the two on the last cylinder to be somewhat loose. The others were all fairly tight. I'm not sure if depending on what stroke you are on if they ever loosen that much. I put the valve cover back on and ran some motor flush through it and then changed the oil again. The sound is still there. When I take off the oil add cap and watch the rockers from above it's almost the tapping is matching the movement of the rocker arms which makes me think I have a faulty lifter. Does this sound correct and how hard would be it to change the lifters. I know this motor doesn't have the plates on the side (like the older models) which allows access to the lifters without pulling the head so I am assuming that I need to pull the head off - fish out the lifters and check them/replace. Any comments would be appreciated. Thanks...
