Guest
·HELP!! I just started having a problem with my Jeep running. The symptoms don't occur until engine is warm.
After a while the engine stops or runs extremely rough. Sometimes it will idle, but extremely rough. I have
noticed a smell of sulphur from the tail pipe only when the engine runs rough. Also it appears the
rear hose coming from the valve cover to the air cleaner seems to have air or exhaust blowing from the
valve cover to the air cleaner. It doesn't happen all the time, it seems to run normal after I stop and re-start the engine
for a short time.
I have put gas into the carb while this happens and it dies. I don't think it's relater to the fuel.
258-6cly. Rebuilt 30K ago Carter BBD carb
for a short time.
