I'm seeing more and more simple wiring problems that are costing people money and time hunting for a 'phantom' problem...
95% of all charging system problems are bad grounds.
The other 5% are broken down to, 4% monkeys with wire cutters under the hood, an 1% defective hardware...
Very rarely is it the fault of hardware when an electrical system problem is persistent...
If the alternator goes bad, you change it, problem solved.
If the regulator goes bad (if so equipped) you change it, problem solved.
Fusible link goes bad, you change it, problem solved.
Monkey with wire cutters under the hood....
Who knows where to begin tracking the problem down...
Grounds...
The factory probably saved $50 per vehicle by not supplying the correct ground wires, (about $2 worth of wire and ends, and $48 worth of labor getting high school drop outs to install the grounds at $25 an hour...)
We've said it before, I know we'll have to say it a thousand times again...
No such thing as too many grounds...
The Starter is the largest current draw on the vehicle.
You have a large positive wire going more or less directly to the starter, but where is that large ground wire that should go directly to the starter too?
Put your primary ground cable directly to a starter bolt.
How about the alternator?
It's the second largest current draw, and it normally doesn't get a ground wire at all!
Every bit of current used by your vehicle is produced by the alternator making it the MOST USED circuit in the vehicle, and it doesn't get a ground wire from the factory? Does this seem right to you?
If you have a 10 Ga wire coming from your alternator, run a 10 Ga. ground directly from the battery to the alternator case. (8 Ga. ground if you have an 8 Ga. hot lead)
Brackets aren't good enough, the brackets and the bolts are painted, will rust, and bolts come loose, all leaving the alternator with out a ground.
How about those ignition systems!
Most rely on a ground through the distributor housing...
Have you ever pulled a distributor and seen the gunk that builds up on them over time? That stuff makes a good insulator!
And then the poor ignition has to rely on loose fitting, moving steel parts for a ground!
Most people are amazed when an ignition system component quits working...
I'm dumbfounded they work at all!
And like that isn't enough, most engines aren't grounded adequately.
It's real hard for your new $700 high output ignition to get the plugs to fire when you didn't spend $5 on a ground cable for the engine!
They complain that the engine doesn't run right when it's cold...
But the electric choke can't get a ground to work...
The ignition module can't get a ground to work, the high voltage can't get a ground to fire the plugs...
The starter 'drags' or 'It eats starters'.....
Ground the next starter and see if that helps!!
My Dash lights/ Radio(s)/ Heater-AC/ won't work or blink on and off, my tail lights won't work, and when I turn on the right turn signal, the right tail light goes out, and the left turn signal blinks real slow....
ALL GROUND PROBLEMS!!
The factory was too cheap to install proper ground wires on this stuff, so you have to.
CJ Dave said you should treat your Jeep like it was three or four different and separate devices...
The Frame, so ground it.
The Body, so ground it.
The Engine, so ground it.
The Fenders, so ground them.
This is REAL good advice...
Lights in particular should have a ground ran to each of them.
It sure doesn't take long for corrosion and crud to build up between the light sockets and the (marginal at best) body ground, so if you run a ground wire, you can be sure your lights will get a ground and work when you need them...
Like when you are broke down on the trail, (or approaching a sobriety check point after a day of wheeling!)
Remember, check the ground FIRST, then check the power source....
Most of us have older Jeeps, and no one has to tell a Jeep owner about rust and corrosion!
OK Then....
(This is what happens when I forget to take my medication /wwwthreads_images/icons/tongue.gif.... PROZAC! It isn't just for breakfast anymore! /wwwthreads_images/icons/blush.gif)
That is all, end of rant!
Grounds...
OK Then....
