The stock pump put out 70 psi when the high pressure line is restricted. The regulator controls rail pressure by dump excess fuel to the return line. I would say you need a pump that will hit 20+lbs. I think at idle, pressure is supposed to be like 17 lbs.
Anyone with a factory serice manual?
