At the expense of sounding like a complete fool, I have a question about installing a lift on a CJ or YJ. Is it easy? I preface that with the following observations:
1. I see tons of Jeeps (and other vehicles) with lift kits installed on them. I can't imagine that every one of them are suspension experts.
2. I was reading through some of the posts here which were discussing lifts. One of them was referring to a Rubicon Express lift. After visiting their website, I happened upon the "Instruction sheet" to install the lift. It was exactly that, a two page instruction sheet which I can only assume is printed back to back on one sheet of paper.
How is it possible that a large modification to a vehicle's suspension consists of 40 steps on two pieces of paper?
I understand that it is possible that it is quite easier than it appears to be, but I am quite skeptical. It is one of those situations where the installation instructions are as simple and generic as possible, meanwhile when you try to do the install yourself you run into 500+ other things that you wouldn't even know where to begin.
Rubicon Express 2.5" Lift Instruction Sheet
Thanks,
Sean
Thanks,
Sean
