Willy,
I saw one of the 6.5 motors mentioned at the diesel page roundezvous. Nobody that I know of has a 6.6 in there 80's or 90's body style truck. As there have been very few, less than 5?!? on the open market. Someone on TDP got a dmax on ebay recently, but who knows as of yet what he is going to do with it. You would have to go to the dealer and hope you can buy one crated. Right now the Dmax plant is building less than/barely meeting demand for the 25/35 series trucks, and the fact that next month a new 4500/5500/6500/7500 series is coming out using the dmax as it's base motor. The 45/55 series will have a sfa 4x version, probably late 02 to early 03, along with ext and crew cabs. The 45/55 series is only offered with the 6.6/8.1 zf6sp and Allsison.
You will probably need to do a body lift as the 6.6 is taller than the 6.2/6.5 blocks. And definitly if mounted with a Allison. Even the 01-2 trucks have body lifts to handle the Allison.
re a cummins. This is very do able, in both the 80's and 90's bodies. I've read/heard that The Turbo Diesel Register (yes I know its a Dodge diesel site)has insructions on installing the B5.9 in any of the big three trucks. The 90's body in 4wd is the hardest of the bunch to install a 5.9, due to the front IFS system. But if you're doing a SFA, this should not be an issue!
Right now if I was to build my truck up, I'd do a Peninsular Diesel long block and start adding the goodies needed to build up a 6.5 to over 300 ponies/ 500+ ft lbs of torque. It's very do able in any yr truck that is stock with a 6.2/6.5.
If there is a ph# for them, I would call them and get info. I believe there are a few others advertising on The Diesel Page that offer low compression motors for sale also, but Peninsular is probably the best manufacture.
Marty
