driveshafts
318 Views 2 Replies 0 Participants Last post by  **DONOTDELETE**
i currently have a 1984 cj - 7 with a wrangler engine & tranny from a 1995 i recently broke my drive shaft and had one custom made now when the jeep move the whole drive train moves like it was out of line the shaft was properly balanced what should i do ? and does a cj-7 tranny match up with wrangler engines? thank you
what do you mean "moves like it was out of line?" if it vibrates, you may have damaged one of the yolks when the shaft broke. my friend's front driveshaft did and it too another broken driveshaft before we figured out the problem.
Nick Hagen
1995 Wrangler
Checked the rubber tranny mounting if you have one.
I sheared mine off from excessive torque. It looked good at first, until
I pulled it. The whole thing was separated (rubber from the plate).
I changed it to poly mount now. This could be the problem.
Also, check all the tranny mounting bolts, make sure they're tight.
If they're loose, it feels strange when you drive/shift.
Dody
