Guest
·I was wondering if there was some sort of formula that you use to figure out the length of your driveshaft, like x inches lift= x inches
of driveshaft length.
also, to make a cv driveshaft, is that an actuall cv joint, or just 2 u-joints in line? and do you do it at both ends or just the end that is
nearest the t-case?
TIA
MAB87YJ
That which does not kill you, only serves to make you stronger
nearest the t-case?
TIA
MAB87YJ
