I think this is a common problem with alot of Chevys. When I got to open the door of my Burban from the inside it does not open. I have to pull really hard on the handle and then push extrememly hard for it to open. It has gotten worse in the last 4 times I have opened the door. I think that it might be that rod that connects it to the latch. I think I will pull the door panel and then tweak that rod to take up some slack to it will open easier.
Has anyone else ever had this problem and how did you solve it? Is there something else going wrong that I should look out for. I have replaced an inside door handle before on another burban and I didn't like doing that so I hope not to go through that hassle again.
Thanks, Ryan
Thanks, Ryan
