1 - 8 of 8 Posts
Flatties are know for their flexy frames and stress cracks right? They are also known to be light weight but be very underpowered right?
Here is what i am thinking: Take the 134 and 3 spd out and replace them with a 90s 2.5L and AX5. The 2.5L is light weight, FI, makes decent power (150Hp right?), doesn't suck gas and the AX5 is plenty strong to handle a 2.5L and it is light. This would be a light weight combo that wouldn't crack your frame and still provide good performance. The only problem is no one makes a AX5 to D18 adapter. Is there any to do it using the dana 18?
Sold the CJ... Cant wait for the next time around!
one more thought. I dont know how similar the two engines are but an Iron Duke out of a mid 80s GM has TBI. Maybe it would be easier to do an Iron duke/T5 or T4??/dana18 ????? I dont know if it would be worth the trouble though...
I would throw in the nv231 or put a d300 t-case in and swap out the axles they usually arn't that beefe anyways, might want to give advanced adpaters a call.
BarrelRoll
97 TJ 30" ko's stock but not for long
welding machine.../wwwthreads_images/icons/smile.gif just kidding..
Muddynut
/wwwthreads_images/icons/cool.gif 78 CJ7 "Issues" /wwwthreads_images/icons/cool.gif
swappin axles would cause this to be more trouble than its worth. AA and Novak dont sell a thing for AX5 to d18. besides it is just a thought, dont even own a flattie... (yet/wwwthreads_images/icons/smile.gif). The reason why i have never heard of it is probally because no one has ever done it.
Problem is the AX15 is about 6 inches longer than a T-90 and the driveshaft will end up being way too short. Flatties have an 80 inch wheelbase.
Josiah
Hillsboro, OR
1955 Willys CJ5 Buick 225 V6 160HP 270ft-lbs, T90 trans, Warn OD, PTO winch, Spicer 18 T Case, RS9000's, Dana 25F/ 44R,
5.38:1 gears, 11" brakes, Bestop Supertop, Hurculiner
well ok that makes sense... But how do guys fit 350s and auto trannies in then? Arent most automatics longer than sticks? -Tim
There are a couple auto trannies that are short. The TH350 is 21-3/4" long, which sounds daunting, but when adjusted for the bellhousing, it is equivalent to a ~15-1/4" transmission. Which isn't too bad, if you can come up with a CV driveshaft. The nice thing about a Dana 18 transfer case is that it is nice and thin and the driveshaft is offset and low down so the angles are better for the ujoints than a 20. That's only 5.5" longer than stock, which is crowded but doable. See:
TH350 in SWB
Josiah
Hillsboro, OR
1 - 8 of 8 Posts
