Does a Wagoneer power steering box have the same bolt pattern as a CJ manual steering box????
I presently have CJ manual steering box to do a conversion with, but found out a friend of mine has a power steering box available and I was wondering if they have the same bolt pattern. I didn't really want to get power steering but lately i have said "what the heck, i'll try it.
Thanks for any info
Dan Stewart 1963 CJ5 "Caloosa Jeepers" member
Re: Does a Wagoneer power steering box have the same bolt pattern as a CJ manual steering box????
At a minimum you will need his pitman arm and the lower steering shaft. The power and manual are different sizes and spline counts.
Yes, the Wagoneer has the same bolt pattern as your CJ manual box. Check the spline count and diameter of the input shaft and compare it to yours. On CJ's the power and manual boxes had different sizes, but some of the Wagoneer power boxes have the same input size and spline count as the manual CJ box. I know this because I have one. Just needed a CJ power pitman arm.
