Re: Differeances in 231\'s?
you have a 23 spline tranny since you had the 6 cylinder. from my understanding the 23 spline t-cases were behind the ax-15, nv3550,
the 21 spline cases were used behind the ax-5 and BA-10.
im not sure if there was a difference between the t-cases on automatics.
from what i understand the TJs had a different output in the back so that you can take off the drive shaft and not lose fluid......so im not sure if you could use yur SYE on a 91-95 case.....
i think your best bet is to get a 97+ t-case from a 6 cylinder XJ or TJ (maybe zjs too) and count splines.
